On Sat I gave the bike a bit of a service, oil, plugs, carb clean, while doing so I noticed the fuel line was looking a bit worse for wear so replaced it. Once all backtogether I noticed a fuel leak, I tracked it down to the tank itself
Can anyone in the SW recommend anyone to repair a hairline fracture in my alloy fuel tank?Failing that, has anyone used the brazing rods you can get on ebay, HTS 2000 or Durafix I think, would they do the job?Cheers,DaveAttachments crack-jpgPreviously david_veevers w…
Previously david_veevers wrote:
On Sat I changed gave the bike a bit of a service, oil, plugs, carb clean, while doing so I noticed the fuel line was looking a bit worse for wear so replaced it. Once all backtogether I noticed a fuel leak, I tracked it down to the tank itself
That weld right next to your finger is a heli-arc weld (or TIG). It is the way alloy parts are put together. Note that the fracture occured at the transition from thick to thin metal. That is typical. It would look ok if the weld were extended to include the crack. Of course you have to mount the tank to avoid any vibration at the mounts to avoid this happening in the future. I prefer a good weld to a patch but it is a lot more expensive.
There are many welders in…
There are many welders in the services section if you choose to do that. Unfortunately you have to click on every single name to find out what region they are in.
Good news on the Services…
Good news on the Services directory. The revision currently under construction will look at your details when you log in and will show the Services available in your area. You will of course be able to extend the search nationally should you wish.
Webmaster
Anna, I'd rather not touc…
Anna, I'd rather not touch it with any modern epoxy, as a very last resort it could be used though.
I have a friend of the family who's a TIG welder and is going to ask his boss if they can do the tank at the workshop (not his equipment obviously). He should get back to me today, failing that I'll be all over the services section like a rash
I've also ordered some of these to see how well they work just incase I need any small ali work done in the future.
Be sure to practice on som…
Be sure to practice on something unimportant and, above all, don't blow yourself up.
With the repair by welding…
With the repair by welding of any crack, it is important to drill a small hole at each end to stop further crack propogation due to stress concentration.
Aye, I was aware of that,…
Aye, I was aware of that, still not heard back from the friend so making plans to do it myself with the Brazing rods. Obviously after practicing on test pieces a bit.
Current plan is:
Clean with water and washing liquid.Fill with Vinegar and Soak for a couple of days.Clean with water and washing liquid.Rinse out.Drill either end of crack.Run my welding gas (Argon hooked up at the mo) into the tank for 10 mins and continue to run while brazing the crack.
I don't think there is much else I can do to do it safely, other than find a place to do it for me obviously
David. I see you are in th…
David. I see you are in the SW. Is Cornwall too SW for you? Weldspray Engineering, near Liskeard, can weld absolutely anything. They have done several ali welding jobs for me over the years, with no problems. Their number is 01579 342299.
BTW, a method of clearing petrol fumes to make it safe for welding is to put a tube over another vehicle's exhaust, place the other end of the tube in the empty tank, fire up the engine and run it for a few minutes. It is then safe to weld. It is a trick I learned in race paddocks, when a repair is needed to be carried out quickly. Usual disclaimers apply......
Cheers. Ian
Pretty much the opposite e…
Pretty much the opposite end unfortunately, I'm in Wiltshire. I have Bristol and Swindon near so there will be lots of places around, it's finding a company with a good reputation I'm concerned with.
I read about the exhaust tip, does it do anythign other than the argon would? I can't see it achieving more than pumping it full of non combustible gases?
It is indeed possible to p…
It is indeed possible to purge the inside of the tank with argon but that is very expensive. Exhaust fumes are free. Argon is used for purging bicycle frames and stainless tubing for perfect welds inside and out.
Specialist Welding Tel: 01…
Specialist Welding
Tel: 01235 820821 - Mereditch Barn Hanney Rd, Steventon, Abingdon, Oxfordshire, OX13 6AW. Worth a call, not far from Swindon,Repaired a damaged Dommie 99 crankcase for me for very little money and did a brilliant job.
Previously charles_bovingt…
Not so as the act of welding will fuse the aluminium and remove the stress concentration. It would be necessary if epoxy was used.
BTW it is misleading to introduce the term "brazing" into the discussion. One cannot braze aluminium.
Sorry, but why can't you…
Sorry, but why can't you braze aluminium?
By definition brazing is the act of joining 2 pieces of metal together with a melted filler material. Soldering is very similar but the filler metal is at a lower temperature.
Welding is the act of fusing together metals by melting the metal and a filler material.
You just need to find the right filler metal that will stick to the aluminium. Thanks for the number, I'll ring them tomorrow, my friends boss has refused to allow him to do the work due to safety concerns (fuel) and that they have too much work on.
I withdraw my comment. I learnt that brazing was a lower temperature process using a spelter filler. Having just had a look at the interweb I can see that contemporary usage is much the same as you describe above. Although I am not sure that the distinction you make between welding and brazing is observed.
I had a small company reco…
I had a small company recommended to me in Westbury in the end. Angel Engineering, did a good job and for only £30...
Only small worry I had was when I told the guy I had cleaned it but that he'd need to satisfy himself it was ok to be welded he told me..."It can only blow up once, I'll just keep my face away from it when I start"...
Not quite sure he was joking, but it wasn't my face so I wasn't thaaat bothered
Pics should be attached.
Attachments WP_20140904_001.jpg WP_20140904_002.jpg wp_- Log in to post comments
Yes Dave mate you need some plastic padding Liquid Metal this will do the job , this resistant too oil and petrol, and will not crack or shrink , it will take heat up to 300 f so give some a try out and stop that leak, yours anna j
