Printing Norton factory notes
This is a great document:
http://www.nortonownersclub.org/support/technical-support-singles/camprep-link
I can't figure out how to print it out. Reading it on a computer requires a lot of magnification and scrolling up and down. Very tedious.
Is there a copyright issue?
I can't access it but I copied it from notes I picked up andmade it more legible. I can send you it if you like.
send me an email address.
jon
jon
Thanks, I am at jonsoonsAThotmailDOTcom. I make technical docs into PDFs for the workshop. I did the attached one in 20 seconds or less from this web site:
mikuni-pdf
jon
Jon it wasn't the format that was an issue, it was reading the typed and "photo stated" oily sheets that had to be typed rather than scanned.
Will send you PDF in the morning.
J
jon
J
SentJon.... let meknow if itsreceived
It will be lovely to have them in pdf format. But when was the originals written? Seems to me it's from the longstroke era?
There is mention of rigid frame with girder forks as well as spring frame with telescopic, so pre-swinging arm.
jon
J
Hi Jon, I've had the same issue as I can only access at the local library. Could you send me a pdf as well please as I've just started building a 1948 Model 30. Please send to richtsteig1AToptusnetDOTcomDOTau
regards
I have a copy of the origonal (more like a copy of a copy of a copy, so very hard to read!). I'd also be interested in a copy that I could print out to have in the workshop as they are very useful. Is there anyway the NOC could make them downloadable to members so that Jon isn't swamped with requests for a PDF copy?
Andy
Andy, email address please. Im not sure whats happened on theTechnical info (Singles)section but my intention was that you could see the originals in PDFand the transcribed version(word)I usein theshed.
Seemsall ofthe "Tech info" on the singlessection is abit off
