Hey,
I have this rear hub, can you have a look at this picture and tell which type has this kind of hub?
Should this hub be fitted in the middle of the wheel or should it be moved towards the axis?
All help is welcomed
Istvan
picture Attachments rsz_…
Picture 1 has E5851 cast i…
Picture 1 has E5851 cast into it. that suggests a Triumph connection.
Looks very ES2 like to me!…
Looks very ES2 like to me! I wouldn't think it is a T*****h
Hi Istvan, This hub is the…
Hi Istvan,
This hub is the standard Norton inter-changeable hub as used from 1932 onwards on most models, and was used post-war on several models on the back wheel only, until 1956. If you could send a photo of the other side it would tell us whether it is pre or post-war. All these hubs have an off-set and if you can borrow an original wheel that will be the easiest way to find the measurement for your particular model. If you are getting a professional wheel-builder to build it he may have the dimensions already, otherwise you need to assemble the whole hub, brake and drum, spacersand spindle assembly and fit to the frame to find the centre line. Regards, Richard.
Hello, i have 1953 ES2 and…
Hello,
i have 1953 ES2 and rear wheel with E5851 hub, standart Dunlop WM2X19 rim (tyre); spokes are the same for all side of hub; lengths are....? I have all in my workshop....wait!
Here: picture of my rear hub!
Guy
moyeu-e5851-jpg
on my rear wheel with E585…
on my rear wheel with E5851 with 19Xwm2 chromed Dunlop rim:
40 spockes (rayons) butted (rÃ?treints) d: 3,6mm and 4,1mm
lenghts (longueurs) 205mm under head, 210mm total
nipples (Ã?crous): 6,35mm (1/4")
head angle: 90? by 5 to 6mm.
OK for you?
Guy
Hallo , Many thanks for th…
Hallo ,
Many thanks for the answers .
Guy Gauthier ! Can you write me , that the spoke nipple outerdimension is 6,35 mm (1/4") or the square ? What size lug in rim ?
Many thanks
IstvÃ?n
Bonjour, morning, guten ta…
Bonjour, morning, guten tag,
6,35mm (1/4") is for cylindrical diameter;
in the chromed rim, holes are 7,0mm aproxim.! (on MY bike...)
GG
jante-es2-ar-rayonna-c-e-jpg
rsz_img_4772-1-jpg
