Anyone any ideas what Norton this piston is off, what type it is and how much its worth?
Its brand new (looks like old stock), never been fitted and is 79 +20"
Attachments img_0177-jpg500cc Manx 30M Norton? Don…
Don't know price but maybe 100 quid and much more if it had the gudgeon pin and rings.
Les
Previously les_howard wrot…
Les
Thank you Les
It has the gudgeon pin with it so it must be £120 - £130
Previously Gordon Johnston…
Previously Gordon Johnston wrote:
Haven't seen something as high compression in years - wouldn't do well on Morrison's cheapest petrol!
I cannot even light my BBQ on Morrisons fuel !!
Have you measured the pist…
Have you measured the piston? I am wondering if it is 79.0mm + .020" or perhaps 79.6mm std (that would be Manx). There are probably stanpings on the piston crown, also maker's name and part number.
Another revealing feature would be the width between gudgeon-pin bosses: 1.2" means International; 1.0" means Manx
Comparing your photo to the two photos of high comp pistons, it is higher crown than both the current offerings. So perhaps around 10:1 compression
If the piston is a Hepolit…
If the piston is a Hepolite one, I can give you the exactly model where it fits.
I need only the number cast inside the piston.
Hans in Chile.
Previously paul_standeven…
Hi paul Its a manx 79.6mm all that you said is correct....I cannot afford a manx!
Hi Carl, Your piston looks…
Hi Carl,
Your piston looks to be a pre-war Hepoliteracing Inter piston. The compression on this is approximately 12.5 to 1 andis designedfor alcohol fuel. You may not find any markings inside as these pistons are made from forged aluminium and are machined inside, whereas most standard pistons are sand cast. Post-war the bore size was increased to 79.62mm which is about5 thou bigger than 79mm + 020 thou. The value would be dependant on a particular owner's use of their machine, i.e. racing/sprinting etc. Regards, Richard.
