Pressure plate looks like…
Pressure plate looks like late AMC. Drum is certainly not heavyweight Norton. Could if be from an AMC range lightweight ?
Previously Tony Ripley wro…
Previously Tony Ripley wrote:
Previously thomas_martin wrote:
looking for missing clutch parts for 1955 88, Are the parts on eBay any good for my model. looks like double primary chain type. As bike came without any clutch got no ref to check.Hi,I am no expert but looking at the parts book for the 1955 88, the clutch is a single chainwheel.Do you have the parts book ?RegardsNo i have the original hand book but not the parts book. TomTony
looking for missing clutch parts for 1955 88, Are the parts on eBay any good for my model. looks like double primary chain type. As bike came without any clutch got no ref to check.Hi,I am no expert but looking at the parts book for the 1955 88, the clutch is a single chainwheel.Do you have the parts book ?RegardsTony
yes i was thinking single chain thanks
Looks like someone is havi…
Looks like someone is having a clear out. I wouldn't buy any of those bits, they are wrong for your bike anyway.
I know where there is a clutch in West Yorkshire, complete for your machine. (Original spec) £90.
07910 483 122
That clutch with the dual…
That clutch with the dual sprocket is for a light weight twin or a Jubilee, Navigator and an Electra. You can use the later 1960's 650ss, or Atlas clutch with the later better type clutch plates. The shock absorber inner cover plate was changed from a counter sunk screwtoan Allan screw one. The chain wheel is a single row chain, and I am sure RGM will do all the parts you need and also a complete clutch. The parts book shows the clutch in its component form along with all the part numbers that are required. That clutch or both types the early and the later one is also show in its laid out component form in the 1957 to 1964 AJS & Matchless workshop manual. There is also the 1964 Norton twins parts book that will show the clutch in its component form along with all the relative part numbers.
Previously Neil Wyatt wrot…
07910 483 122
Sounds good For all the parts i need, as my clutch is missing completely. last owner had plans on a belt drive.
