clutch plate fix
Has anybody ever glued the pads back on that come loose on a clutch plate. and if it can be done what would one use. tight arse lol
Can't think why not,needs to be oil proof and clamped while going off. Try Araldite ,what can you loose?. Let us know if it works.
Its not for the normal clutch plate but the main bonded one that is a bit pricey. been collecting bits here and there and probably got enough parts for 2 or 3 clutches now and seems a shame to dispose of a part that could live on. after all thats what renovation is about.
Would have to be well de-greased first , and maybee the surfaces roughened up slightly, nothing ventured nothing gained.I attempt a repair on just about everything ,as long as its safe to use. The larder fridge was condemmed as not worth repair by the professionals about 3 years ago, the repair cost nothing,it works better now than it ever did and uses about half the power.£500 a new one. The washing machine is at least 15 years old ,repaired 3 times . Its a way of life.
Greetings, recently a colleague who restores 'Military Vehicles' had a dilemma with friction material on some non- motorcycle clutches. This was resolved by a local brake specialist (unfortunately in South Australia) who cleaned, degreased & bonded new material into the housings and linished to OEM specification. Since replacement, the vehicle has never driven so well, so maybe this is an area to investigate?
Rgds Steve
I couldn't get a chainwheel for my AMC clutch, same as the Norton bar Comando, a chap from Australia suggested aralditing a couple of tractor pto plates to it,I had to turn them down to fit but did as he suggested, been on the machine 6 yrs now and never given any problem, total cost around £30 inc. kind regards
