Jump Starter for my commando
I need a jump starter for my 1971 750 commando, the normal suspects (for cars) the connectors won't fit as the battery terminals are a lot smaller than cars, can anyone suggest a jump starter, and if it has a compressor built in all the better.
Have you considered wiring in a lead with a socket that allows you to plug in a jump starter or charger?
No but I might just get a motorcycle battery charger, I can wait for that to work was just wondering if there was such a thing. Are these leads available or home built jobbies
Halfords sell bike jump start leads, OK for a kickstart bike but get hot jumping anything else
For a kickstart bike you only need 16 amp cable or thereabouts with a couple of crocodile clips on either end.
Every rider should carry one of these:
https://www.amazon.co.uk/DBPOWER-8000mAh-Portable-Emergency-Flashlight-Black-Red/dp/B076HJDPTL/ref=pd_lpo_vtph_107_lp_t_3?_encoding=UTF8&psc=1&refRID=GTW3NJ2TPA20AYRF3R55
£29.99 inc. P+P
I can vouch for the claim that it will start medium-size petrol-engined cars; with USB outlet to power your phone as well.
If you have a large diesel, bigger versions are available (at higher prices).
I believe some chargers have leads and connectors supplied for this. There is a wide range available from 'Vehicle Wiring Products'
http://www.vehicle-wiring-products.eu/?jssCart=65940201a3ea53a886ab33a88855f231
I fitted a DIN 'Hella' type socket to my Commando both to supply auxilliary power and to plug in a charger if needed.
din-power-socket-fitted-jpg
