Lower fork shroud
I recently saw an add for Newly manufactured lower fork shrouds suitable for the long road holder forks on the Mod7, unfortunately I cant find the advertisementany more. Do any members know of a supplier of Lower Fork shrouds for the Model 7 long roadholders. The early long road holders have a shoulder machined on the upper slider so the shroud slides down past the seal holder assembly and is secured by 3 small screws tapped into the slider itself. I have seen a slider extention advertised at Andover but this part is fixed to the seal lock ring and is not suitable.
Try Fred Williams his telephone No is 01234 824117. His parts are as good(if not better!) than most available and he should be at stafford this weekend.
smashing bloke, good sense of humour and very reasonable with pricing!
Good Luck - Terry
Thanks for that Terry, I am based in New Zealand so an Email or postal address for Fred would be useful if you have access to either?
Cheers, Marcus
Good Luck - Terry
