Evening all,
Please can anyone through any light on what the numbers mean on my dominator 600 crankshaft
on centre is stamped 10415752, 8744, 5242 stacked with large number closest to centre. Then on each lobe/ear is 253 with one small punch mark which i presume means it been ground but the journals measure 38.1mm.
Any information welcome.
Phil
Update once cleaned up num…
Hmm, looks like a secret c…
Hmm, looks like a secret code to me. My spare one is stamped .030 with D on the drive side of the flywheel and T on the timing side.
Evening all, a further up…
Evening all, a further up date on crank which is cover in numbers, I have include a picture.The centre fly wheelhas three numbers on one side 1DA15752, 18744, 19242 the other side 1DA15752. There is also a 8 stamp on the rim of the fly wheel with a small 14 on the oppsite side. Eachlobe has 253 on top and 596 on each cheek. Any information welcome.
Attachments 99-dominator-crank-jpg- Log in to post comments
I note that it is from a d…
I note that it is from a dynamo engine.These are not standard numbers. A previous owner or a machine shop has added them. They must mean something to someone but, judging by the lack of responses, no-one on this forum.
18744 is the p/n for a mod…
18744 is the p/n for a model 99 flywheel. The flywheel in the pic appears to have been seriously modified. The factory used to stamp the crankshafts with 597 to identify a model 99 crank. Though I do believe some were also stamped with 596. I am guessing that 15752 & 19242 are also p/n.
Attached photo shows other variations of crankshaft.
Attachments some-dominator-crankshafts-jpg- Log in to post comments
Interesting that the facto…
Interesting that the factory used to stamp 597 to identify a 99 crank though I have never seen it stamped on a 99 crank - perhaps the alternator ones were not stamped. I would have thought that factory personnel could tell at a glance an 88 from a 99 crank - or perhaps not...
Previously Gordon Johnston…
Thank you to Phil Haman wh…
Thank you to Phil Haman who has confirmed the crank is from a 99 dominator. An most of the numbers can be explained. Thanks Phil great work.
Update once cleaned up numbers actual read 1DA15752, 18744, 19242
