Is this nut correct? If so, why such a funny shape?
nut2-jpg
Looks like a wheel spindle…
Previously roger_jordan wr…
Previously roger_jordan wrote:
Looks like a wheel spindle nut to me, with the rounded shoulder to accommodate the adjustment bolt.
I should have said it is 7/16 - 20 and it is on the rear cross member spindle. So right thread for that.
No it isn't correct. A no…
No it isn't correct. A normal flat nut is usually fitted so it pulls up tight on the washer. 7/16" x 20 tpi is correct.
Jonathan, Good to see that…
Jonathan,
Good to see that it is not just my bike which has this nut in this location.
Jonathan..........I have s…
Jonathan..........I have seen a few frames, like yours, with sidecars attached. Some had the usual flat nut replaced by the more substantial wheel nut kind.
I agree with that - with a…
I agree with that - with a sidecar attached a large fishplate fits over the left-hand swinging arm gusset plate. The shouldered nuts protrude through the fish plate on to the swinging arm spindle and the top engine plate mounting tube stud. Strangely, the later frames did not have the top stud hole in the gusset plate as the tube was welded - so presumably to fit the sidecar fishplate would have required some careful drilling ? Someone somewhere has got your "sidecar type" swinging arm spindle nut. Cheers, Jonathan and Phil. Regards, Howard
Fascinating stuff, my bike…
Fascinating stuff, my bike had a sidecar in an earlier life so that all makes sense then.
