Plug, grub screw
Found this, now I dont know where it goes,,model 7,, 1954, about twice the size of the timing cover plug, flumoxed am I !!!!
2017-12-09-01-32-32-843-jpg
As you have given no measurements Iam guessing it could be an oilway plug. Have a look on Andover Nortons website at the early 750 parts diagrams (your models big yonger brother) Cranckcase diagragm, crankcase oilway plug Item 22 part number 06-7599 (NME 4590) 5/16 x 26 TPI.
Also Crankshaft Diagram Item 17 1/4 x26 TPI but from what you say maybe too small.
These are Commando diagrams but could give you an idea.
Picture is of extracting a MK3 commando plug which is a unc thread.
If your Model 7 has one it is on the timing side crankcase looking from underneath.
085-jpg
Thanks for that, just under the oil pump, forgot all about that one, :)))
Thanks again.
