Good evening,
The brake pedal of my 1967 650ss was fitted without the spring and the pedal #19994 did not return. So i ordered a new spring. Then i noticed that there is no hole for the marked end of the spring (see attached picture). Do i have the wrong pedal? Can someone show me the exact position of the hole? Then i would try to drill it.
best regards
Stefan
20180708_181443-jpg
Previously stefan_koop wro…
The fixed spring stop can…
The fixed spring stop can be positioned wrong which would get you looking in the wrong place for the lever hole.Bet its in there somewhere,unless you have an Indian copy!
Hello Stefan, Here is a ph…
Thank you Guys !
Previously stefan_koop wrote:
