I recently ordered a listof parts for my Model 77 from Norvil. I received items that either Ididn't need, thatdidn't fit, wouldn't work if they could be fitted, or were produced to all the wrong dimensions and in the wrong material. I have since been told that they were all produced to original Norton specifications and that if I had ordered thecorrect partsI wouldn't have the problems that I now have. This was after talking on the phone to Les about the parts I needed for my Model 77. I am now waiting for a reply to my request for information concerning thecorrect partsthat I should have ordered after explaining the inaccuraciesto him with photos, which I would be quite happy to attach here if anyone is interested.
Most of the items I ordered concerned the 77s steering damper system. So, does anyone know where I can get hold of these twocorrect parts.
2 x Damper discs. They each should be no thicker than 0.100"
1x The long stud that goes down the middle of the steering head. It should be 29cm long, with both ends threaded at 26tpi Cycle thread I believe. one thread 8cm long, the other thread 4cm long.
Please, if you have anything to say on this thread, keep it factual.
Previously Kevin Feltoe wr…
Dear Les. That's right! I…
Dear Les.
That's right! I didn't ask for any part numbers, I ordered parts from your website after being told that they would fit my 77. I was also told that my order would be checked to make sure that I'd ordered the right parts. I was not informed otherwise.
I did not order parts from a drawing. I ordered them from your parts list. I do not see any alternative parts on your lists that would correct the 'problems I have'. I have asked you to 'please supply me with the right part numbers', but nothing yet!
Your reference to 'MJ'and drawings,must refer to another website, as I don't see the drawingson yours. If so, then yes you are right. The 77 picture is on the left and the parts in thedrawing are exactly the same as the parts on my 77. The parts that you supplied me are different. Idid not seethedrawings until after I had ordered the parts from you, using your part numbers.
The damper discs in the picture even look different to the ones you sent me. They should be no thicker than 0.100" if they are to fit a Model 77. Anything thicker will prevent them from operating. I thought that this was obvious in the picture I sent you.
I also ordered steering bearings. They come in two halves. One half should be different to the other, in that one half should have a lubrication hole. You sent me three halves with lubrication holes and one half without. These were all bagged up as genuine Norton spare parts. This may be, but the error makes me doubt the product.
I also receivedtwo lower yoke stanchion clamp studs that were 6mm too long at either end. They may do the job, butlook awful when fitted.
You stated in an email to me that, and I quote, 'We don't just list different part numbers to make up the parts listed to over 13,000 but because they are different'. Perhaps you could explain what you mean by this.
You also state that. 'Every part you have purchased has been made to an original Norton Drawing. That is of no concern to me, if it doesn't fit or it doesn't work.
All the very best.
Kev Feltoe
Hi Kev, to be perfectly ho…
Hi Kev,
to be perfectly honest, I ordered all of those parts from Les at Norvil using my Genuine Norton M77 parts list & part numbers via email. At that time, the conversion list from old numbers to new numbers was not on the Norvil site, but I received an Email from Norvil showing all the converted numbers & I OK'd for the order to be placed. All the parts fit perfectly with the exception of the steering damper rod, I think I had to shorten it as I recall. The studs, nuts, and bolts on the yokes I wanted in stainless, and I dont believe Les stocked those items in stainless at that time, so I bought them from Molnar Manx, but I needed to specify exactly what I wanted: diameter, thread pitch, length, etc.
As you and I both know, the M77 was the bastard red headed stepchild from Norton, and there are many weird quirks on them.........that's why I like it, anyone can restore a Commando
FWIW, I see Norvil now stocks the correct shape rear grab rail, but smartly doesent drill all the holes, as the distances varied from bike to bike (ask me how I know!). Now if only someone would make the correct header pipes for the M77 !!!
All the best,
Skip Brolund
Hi Skip. Nice to hear from…
Hi Skip.
Nice to hear from you and interesting stuff. The rod, as you say was too long, but if I had just shortened it there would not have been enough thread. It was trying to thread the SS rod where I came completely unstuck. Its good to hear that the parts you ordered fitted, but if you ordered the friction washers and they fitted, how thick were they?
One maingripe of mine is that even though parts might 'fit', they are not the same asthe original parts. If I want a stud to fit a yoke, I'd rather receive one that is the right lengthinstead of too long. Yes, I can cut it down and have done, but that is not the point. Generally, If a spring is made of much thinner steel than the one it is replacing, it won't be as strong as it ought to be, especially if it is the same length and diameter with the same number of coils. In this case it is a whole lot weaker.
I could go on, but won't. It is just disappointing. I'm sure I'll survive.
Cheers.
Kev
cant-operate
Previously Kevin Feltoe wrote:
Hi Skip.
Cheers.
Kev
Dear Kevin, You asked me to explainhow we can we make over 13,000 items which is more than double both of our nearest competitors.
If you look at either of their websites they both suggest that B2/642 can be swapped for 067661, F11M2/642, 16164, NM16164, 060336, 061136 and NM13457 when they are all differentand each has a specific number.
We also make parts back to 1913 that neither of them do.
We have all the correct parts for your 77 in stock but you supplied the part numbers for a featherbed.
B2/642 is 1.837" but you ordered 067661 which is 2.062" long.
B2/203 is 11.500" but you ordered 030326 which is 12.500" long
B2/202 is 14 gauge but you ordered 030328 which is 22 gauge
We are very disappointed that a branch secretary can order the wrong information on other peoples websites and then blame us.
Unfortunately we cannot supply you either of the two studs because we only manufacture them in the"wrong material"or stainless for short.
Still, at least Skip can have them.
Regards, Les Emery
Previously leslie_emery wr…
Hi Skip.
Cheers.
Kev
Regards, Les Emery
Dear Les.
I thank you for your concern regarding your nearest competitors and Branch Secretaries.Hilarious!
I think however that you have me confused with someone else. Your thousands of items going back to 1913 are of no concern to me and never were, so it rather looks as if you are using obfuscationto advertise your business on the NOC website. Naughty!
The facts are these.
If I do a custom search on your website for B2 202, I'm taken to www.norvilmotorcycl.co.uk/numconvert.htm, where I'm told to use 030328. Likewise, for B2/203 I'm told to use 030326. And for B2/642 I'm told to use 067661.
No other website or business had anything to do with the incorrect parts I was sent by Norvil.
If the Web and Data Manager decides that your posts are nothing but a crude attempt at advertising, I'm happy for him to delete this thread.
I've stuck to the facts and said my piece. That's all!
Regards.
Kev
Dear Kevin, Thank you for…
Dear Kevin,
Thank you for letting me know that our number conversion had reverted back to an earlier version.
All numbers in the illustrated parts catalogues are now current under the numbers listed.
Regards,
Les Emery
Dear Kevin, You neither asked for, or were given any part numbers. You only wanted to know whether the correct parts were in stock for your 77. Please note that the drawing on the left of MJ is for the 77 and the one on the right is for the 88. All of the parts you ordered were off the 88 drawing except the damper discs. The original factory drawing shows this as T347, 1.390" ID, 2.500" OD thickness 0.125 and cost 1s and 4d.
Regards, Les Emery
