Commando frames.
Can anybody tell me if there is any difference between a Commando 1971 frame and a 1975 frame? Thank you! Regards from Svein.
Various brackets and holes plus the headstock angle changed by 1 degree so 850 frame needs 850 yokes so you get the right trail back. Center stand may be differently mounted as well.
Previously svein_marken wrote:
As mentioned above Headstock angle is different, this has quite an effect on handling; even gets a mention in tech talk on norvil website under 'my bike weaves'. So steer clear of 71/72 frames if possible. later frames are easily identified by larger/extended brackets where rear shocks fit.
For those who have a 71/72 bike and think it is fine, I would ask have you ridden a pre 71 or 73 onwards one - they are noticably different when you get motoring.
regards Martin
Previously paul_nicholls wrote:
Also the rear frame loop is slightly narrower. You can't fit a fastback tail fairing to the later frames.
I'm pretty sure it is the italian frames only that are wider an won't accept the normal fastback tail. I own 2 75 frames that will and 2 that won't accept the FB tail. I also have a 73 750 frame that is a wide loop. Most early frames are narrow loop.
Since my research... a long time ago, I made a altered FB mold that works on the wide loop frames.
http://atlanticgreen.com/images/xdcp609.jpg.pagespeed.ic.2-_w8aFSOe.jpg
Previously arne_eftestol wrote:
Svein...
Hva er dette for noe ???
Husk , mer en en sylinder er trÃ?bbel...!
Mvh
Arne E.
Kanskje litt stÃ?v pÃ? hjernen etter timer i bua!!!!
