Hello All
I am in the process of restoring a 1938 CS1. Can anyone recommend a plating company that can refinish fasteners & fittings in the correct satin or dull chrome that Norton originally used? It seems to have the unusual properties of being thin enough to not interfere with thread and other tolerences, and not flake off when a spanner was applied, yet gave good corrosion resistance.
I am also agonising whether or not to have the tanks re-chromed! The metal is good, and dent-free, but obviously irreplaceable if over polished. Has anyone used a company that understands the problems and has come up with near perfect results on chrome plating petrol & oil tanks?
Finally, has anyone ever seen any magazines or books with detailed original photographs of a CS1 around this year, asI am trying to get the restoration as original as possible. I have got the usual re-prints of parts list & catalogues, but the catalogue pictures, (drawings?) don't show fine details.
Thanks very much
Roger Hainsworth
Previously wrote: Hello Al…
Previously wrote: Previous…
Hello All
Thanks very much
Roger Hainsworth
hello the guy you need is Carl Russel at Quality Chrome and he as a web site www.qualitychrome.co.uk this guy its the best in Chrome plating ? Hope this Helps
Anna Thank you for that. I…
Anna
Thank you for that.
I have been in touch with Carl Russel and he is confident that the tanks I have can be re-chromed. Apparently if a tank is pitted successive layers of copper basecoat can be applied and polished out to build up a finish, rather than grinding down the steel tank. Time consuming and expensive, but worth itfor a 70 odd year old tank. He was not so familiar with Norton satin chrome, but said it could be replicated.
I also found another company, Derby Plating Services 01332 382408, who specialise in vintage cars & bikes, and are familiar with satin chrome - dull nickel plate with chrome on top.
I had a couple of fairly e…
I had a couple of fairly expensive disasters with Dull Chrome and learned the hard way that many chromers intermix the terms 'dull chrome' and 'satin chrome' and always say they can do it but these are not the same thing. Modern 'satin chrome' is actually quite smooth, although not as reflective as bright chrome. Unfortunately chromers won't generally talk about the processes.
I suspect but haven't been able to confirm that the solutions differ for dull chrome and that inevitably those used at the time would have been chromium-6 solutions and this has now been outlawed by the EU. With the low demand for dull, they probably haven't researched new ways of achieving the exact finish.
Ken McIntosh in New Zealand (McIntosh Manx) makes very nice dull chromed fasteners and some other parts and his finish is indistinguishable from undamaged period originals. It occurs to me that perhaps the laws are different there.
The best finish that I have obtained in the UK was from Collins Chemical Blacking in South London. They did a brake pedal for me that I'm very pleased with.
I would recommend that if you're as intent on accuracy as you sound, you go along to a chromer with an original sample and ask to see what they can do. It might avoid expensive disappointment and we're all a bit vulnerable when not satisfied with chromers as we HAVE to have our bits back.
Thanks Richard B****y EU s…
Thanks Richard
B****y EU strikes again!
I will check out Ken McIntosh & Collins, & a good idea to try some chrome samples. IfI don't get anywherewith the chrome I will trystainless steel. Ithough toexperiment with polishing then trying different bead and other media in my blast cabinet to see if the satin finish can be replicated.
While on the subject of stainless, anyone with a cammy Norton should check out Paul Norman's brilliant web site www.racingvincent.co.ukA big range of stainless special components & fasteners for OHC engines, plus a lot of other parts. Also, very detailed instructions, with tips & photo's, on rebuilding cammy engines.
Roger, In addition to Nort…
Roger,
In addition to Nortons specifically, dull chrome was quite widely used on War Department machines during the early part of the war, including silencers etc. There is no doubt that blasted stainless can give a fairly close effect and it's sometimes possible to very gently blast bright chrome (but it doesn't always work). If you want to see some blasted stainless, have a search on the WM20 forum.
One of the problems with Nortons of course is that they seem to have used special fasteners for everything. If your search for authenticity leads you to have the screws with 'inclusive' washers re-made, can you put me down for a box please ?
You're right about Paul Norman's site, and a nice chap to deal with.
Rich
ps I'll happily mail you some photos of a few bits of chromework but I've given up trying to post photos on here.
Thanks Richard
Rich Thanks for that. Paul…
Rich
Thanks for that.
Paul Norman seems to be a good man for getting replica parts made, if there is a demand, maybe he is the person to contact for the screws you mentioned. The only engine part missing on my CS1 is a valve lifter spindle, Paul says he is hoping to have some made in the future, to add to the lines he already sells.
Will let you know how I get on in my quest for the right finish. If you want to get in touch direct my email is roger@grandiflora.co.uk
Roger
Hi By coincidence the conv…
Hi
By coincidence the conversation at work today came round to chrome plating tanks. There may be another option, spray on chrome. It is a 3 layer process - base coat, metallic layer, then protective top coat. It would not require aggressive polishing and could be applied to a tank with filled dents. I have no experience of using this, don't know if anyone is offering the service in the UK, or how expensive it is compared to conventional plating. Might also be a bit too bling for our bikes - just look at some of the photos on the website. http://www.sprayonchrome.com/techdata.html
Just a thought
Ian McD
Previously wrote: Hi By co…
Hi
Just a thought
Ian McD
Ian
Thanks for that. I used to be involved in paint finishing years ago, but had never heard of this finish before - it looks somewhere between polished aluminum and conventional chrome, and definitely a good option for a dented tank. I guess a call to sprayonchrome would show if anyone offers this finish in the UK. I'm veering towards theconventional finish with aheavy copperundercoat at the moment, which should minimise polishing through old steel. One of the chromers suggested, without my asking - a good sign, that I supplycard templates to show where the painted panels go, so that these areas don't have to be highly polished.
I willkeep you all posted on the result!
Roger
Hi Roger, Just spotted thi…
Hi Roger,
Just spotted this thread - and by the way, thank you for your very kind words, and from Rich Payne as well.
Again, on the subject of dull nickel plating, which was Norton's favourite fastener finish, I too have struggled to find people who will do it any more - health and safety and all that, however, the last company I did have it done with were a specialist company called S&T Plating in Bristol. They are most definitely not cheap, but the quality was brilliant, best I have ever seen, and particularly their chrome plating was exceptional, crisp edges, no polishing off of writing, each part individually wrapped. For those special restorations, these guys are worth using.
By the way, I have found one of the best tips when sending parts off for dull nickel, is to ensure you do as much of the de-rusting and cleaning up of bolt heads yourself - particularly getting good crisp edges. The problem used to be with platers, is that they just used to dip and degrease dull nickel parts and throw them into the nickelling bath - it used to be quite cheap - quite often you would pay by weight, but you get what you pay for!
Best wishes,
Paul Norman
Hello All
Thanks very much
Roger Hainsworth
