Hi All,
Can someone tell me where I can get a servicable carburettor stub (manifold) for my 1954 ES2 Norton?
Regards,
Albert
Albert, can you give me th…
Previously wrote: Albert,…
Albert, can you give me the critical diameters ? I might have one.
Are they all threaded 1 3/8" x 24tpi ? - What size stub do you need ? (Internal diameter for the carburettor) ?
Rich.
I will check it out this evening and get back to you Richard.
Many thanks,
Albert
Previously wrote: Previous…
Rich.
Many thanks,
Albert
Hi Richard,
These are the dimensions of the stub:
Threaded end 1 3/8" 24tpi.
carb end outside dim 1 1/4" and 3/4" deep.
overall length 3"
Regards and thanks,
Albert
Albert, The one that I hav…
Albert,
The one that I have here is the same length as the side-valve stubs - 2 3/4" and the diameter measures up as 1 15/64" which is an odd-sounding dimension and it doesn't look worn or damaged.
I bought it because it had a nicely patinated dull chrome finish but it's too large for my 16H. I don't know what it was fitted to.
If you can send me a personal message with an e-mail address, I'll szend you some photos.
Rich
Rich.
