Could anyone please shed light on what the correct figure should be for this engine - I have the club Single DVD which gives the figure as 38 degrees for a late(ish) Model 50 being reassembled. Figures I do have vary e.g. 1962 Norton Maintenance Manual gives 38 degrees or 17/32" or 13.5mm; 1959 Norton Maintenance Manual gives 7/16" or 11.11mm (seems about right for my '49 engine?) and a Norton Singles book gives the figure of 3/8".
Any help appreciated. Thankyou.
John- Main-Smith reprint o…
What does it work out at f…
What does it work out at for a 100mm stroke? Regards John.
iv just done my es2 motor…
iv just done my es2 motor i just put piston tdc
then have the valves rocking each side of tdc slight overlap runs spot on
fast rev good starting
Previously wrote Much obli…
Previously wrote
Much obliged Richard - I'm confident that the figures will be the same 1949 or 1950 (don't think the engine changed between those years). I'm going to use piston travel of 5/8". Did you mean 100mm stroke for your ES2?
Thanks again - John
John (both Francis & W…
John (both Francis & Whiting !)- My apologies and I am feeling very foolish! The figures I gave you were indeed based upon a 100 mm stroke and in my reply I quoted the bore- that would have been a short stroke engine indeed ! Again, these are for ignition on full advance. Interestingly I have tried to gauge points opening with both the slip of paper method and by continuity across the points with a multimeter and the result was the same either way so the paper method is fine with me. Sorry for any more confusion from over here in the colonies- Richard
John- Main-Smith reprint of the Norton workshop manual for my 1950 ES 2 gives the ignition timing in piston travel and calls for 5/8 " BTDC with the mag set on full advance. I have ( with my daughter's help as she is the math wizard ! ) worked out the math solution via trigonometry to convert this to degrees of rotation. Given a 79 mm stroke ( 39.5 mm crankshaft throw) and a 7'' connecting rod length this equates to 41.622 degrees BTDC. I checked this by measuring the piston travel with a dial indicator and degree wheel/pointer set up and it was spot on- I do not know if these figures apply to your 1949 engine & I hope I haven't confused you further .Perhaps another member will know if the timing specs for 1949 are the same as for 1950 - Hope this helps-Richard
