Manual advance
I have an ES2 with a Lucas magdyno. This is my 1st bike with magneto ignition, and I just need to confirm the actual position of "full advance" on the advance/retard control lever. I have read conflicting information on the action of this, but, from observing how the lever moves the face cam, it would appear that applying tension to the control cable advances the ignition and rotating the lever so as to slacken the cable retards it. The Norton Instruction manual implies that as a Norton owner, one should already have a working knowledge of such things. However, I don't and would be grateful if someone could confirm my observations before I set about the ignition timing.
Gordon
The 'Tight wire advance' is normal on Nortons (and a bit of a nuisance if the cable breaks !) However, it will depend upon the magneto and the points housing being original but I'd suspect that your observations are correct. What year is the bike ?
It varied over the years but on mine, which has the inlet cam driven by the exhaust cam, rather than direct from the crank pinion and thus a clockwise magneto (viewed from the drive end), the A/R cable enters next to the cylinder and relies on a tight wire to hold full advance.
Hi a simple check to carry out would be to run the engine at tickover and move the lever, when the tickover speed rises it is advanced and when it slows it is retarded, this will show you where advance and retard positions are regardless of if the original magneto is fitted or not.
The ES2 engine dates from 1950 and I believe it to be the original megneto set-up. The points rotate cw when viewed from the points cover end (guess this would be ccw from the drive side). From your comments and my observations, I'm now pretty confident that applying tension to the cable will advance the ignition.Gordon
You should be able to watch the points with the points cover off. Rotate the engine until the points are about to open, i.e. rotate until the poinst open, then back off a bit. Best done with the spark plug out and in top gear, just turn the rear wheel. If the points open when you apply tension, you are advancing the ignition.
Personally, I don't like tension advance, though my Rudges have it. The ignition can retard without you noticing, until the lack of performance alerts you. A cable break fails to full retard too which means having to ride home veery slowly. It's easy to find an alternative points housing at autojumbles and convert the MO1 magneto to tension retard.
Thanks for the replies on this query. I'm am now sure that I have a 'tension advance' system. I have also learned that there are 'tension retard' systems as well and this is probably the reason for the conflicting information which I have read.
Gordon
Hi Gordon,
If your Easy Two is a 1950 model then the magdyno should be a "slack advance" type, that is when the ignition is fully advanced, the spark control lever is hard against the stop and the control cable is slack. That way if the control cable breaks the ignition isn't suddenly retarded and your engine's power doesn't go south. The engine can still be started on full advance if one doesn't mind getting bitten by the kick starter, just don't lock the knee joint.
Regards,
Albert
Gordon
Hi- I agree with Albert-My 1950 ES2 is as Albert says. Regardless of which way yours may be rigged, look at the rotating points and the ignition is advanced when the facecam plate is rotated fully against the stop in the opposite direction of points rotation- i.e.: clockwise point rotation/anti-clockwise(counter-clockwise here in the states) rotation for facecam for advance and vice versa. This places the ramp in a position so the points open sooner rather than later- Hope this has been of some help- Richard
