1943 16H
Hi Guys, I have a 1943 16H and I can't find out much about settings etc, is the ignition timing the same as a '39 model, also the tappet clearance? Also it has an oil pipe union and a short length of pipe going nowhere coming from the left side of valve/tappet box, I gather this is to lube the lower tappets etc, but where from? Hope someone can help please, thanks in anticipation.
Antony
1943 would be a WD model, which were to 1937 spec.
There is a great site for wartime Nortons wdnorton.nl
If i understand the pipe query correctly, that is just a gravity drain. Excess oil from the tappets runs to ground via the pipe. There should be a similar pipe on the underside of the magneto drive.
Welcome to the wonderful world of sidevalves
Iain.
As Iain says, your bike is a WD 16H, there is no automatic lubrication of the valves, you have to use a grease gun on the nipples every few hundred miles. The book says 500 miles. The ignition timing is 35 degrees or 7/16"BTDC. The tappet clearance is inlet .002" Exhaust .003"
I hope this helps
Dave
