          Hi Guys
Any ideas where i can buy the oil seals on the backplate clutch cover . I have the large rubber one for sealing the two halfs of the clutch basket oil bath , its the other ones at the rear
Billy
I'm guessing you mean the…
I bought a felt washer for…
I bought a felt washer for a Commando which fitted in with the use of a small screwdriver.
I'm guessing you mean the sliding circular plate arrangement (about 3" or so diameter)? I just recently bought a small kit from Fred Williams (don't have his number - sorry) for my ES2 primary chaincase. Was just a case of making a felt seal then assembling the parts using the rivets provided in the kit. Hope this helps, John.
