Good morning.
I have a 1950 Norton 500 single and I think it is an ES2 (As the bore is 3.11 in). The cylinder is sleeved.
The left engine case has A35220o then 79X100 near the top then at the 9 o clock position it has A600.
The frame has B48598 stamped below the fork brace. the frame has 21" front and 19" rear rims.
I am looking for a parts book so that I can put the engine back together ( need piston rings, cylinder gasket, and head gasket, as well as the push rod seal as a minimum).
Your help is appreciated.
Thank you.. Cheers..
Dan.
The parts book, and lots o…
Hi Darwin, Your engine, fr…
Hi Darwin, Your engine, from the number is a 1946 Model 18 (500cc) the same as an ES2, and your frame is a 1947 ES2, so should be a plunger frame with tele forks.
Previously wrote: Hi Darwi…
Thanks Dave. I guess this was a Frankenstein from numerous other motorcycles. Yes it has the plunger rear suspension. Your help is appreciated and now maybe I can get this thing back on the road if I can find the gaskets and seals.
Thanks again ..
Dan..
Thanks again ..
Dan..
The parts book, and lots of other manuals and parts books, are on the Norton CD ROM form Kim the CD Man.
kimthecdman@techinfo.com.au
