          Hi All,
I have a 1960 ES2, I am having a problem with the quantity of primary chaincase oil, Is the screwed plug a level or a drain? if its a drain whats the correct quantity of oil. I cant find mention of it in the manual.
The level/drain plug seems very low hardly wetting the chain, I was going to use ATF unless anyone thinks this is a bad idea?
Thanks Rob
The screwed plug is the le…
It is a level, you only ne…
It is a level, you only need just enough oil in the bottom of the case to touch the bottom of the chain. Then the chain will splash it around as it spins.
I use ATF in the fully enclosed oil bath case on my Royal Enfield and it works very well, would deffinately reccomend it for use in primarry chain guards.
Thanks very much for the i…
Thanks very much for the info, Much obliged.
Rob
The screwed plug is the level. One way of checking primary chaincase oil level is to add oil a little at a time and kick the engine over (ignition off of course!) and feel the chain through the inspection hole. When a little oil appears on your finger, the level is right. I use tractor universal oil (high-spec 10-30 diesel oil, no additives, used for engines, transmissions and hydraulics and also cheap) in my chaincases, and my tractors. ATF should be fine too.
