hi can anybody give me the measurements or a picture of the rear fuel tank mount bracket on the 19s or maybe another model Norton is the same. any info will be appreciated. the part no is e2/845.
thanks bish
thanks Ian that would be g…
thanks Ian that would be great.
regards bish
OK: length 180mm. Width 38…
OK: length 180mm. Width 38mm, reducing to 28mm in the centre. Height 30mm, includes thickness of the bracket. Mounting holes in cantre 75mm from each end.
Do you need any more than that?
Ian
hi Ian those measurements…
hi Ian those measurements are good i can work from that. thank you very much.
regards mark
You're very welcome
You're very welcome
Will do, give me a day or so!
