Does anyone know what size the oil pipes on a 30's inter are? The holes in the crank case are 1/4 BSP and the oil tank is 3/8 BSP. Does the stepped nipple go at the crankcase with a 3/8 pipe used or at the tank with a 1/4 pipe? Are the feed and return pipes the same diameter?
This thread might be of so…
(this time with the thread…
(this time with the thread ref included - sorry)
This thread might be of some help.
http://www.nortonownersclub.org/noc-chat/technical1-singles-forum/847491219
I think oil pipe sizing on pre war bikes were pretty uniform.
Hi. The oil pipe unions th…
Hi.
The oil pipe unions that screw into the crankcase are 1/4 BSP stepped up to 3/8 BSP (at the crankcase end)for the oil pipes to attach to.
Regards.
Ian.
Here's a piccy of the uni…
Here's a piccy of the union that goes into the crankcase. Both return and dlivery are identical. It is recommended that they are bored out to 9/16".
Regards,
Ian.
Ooooooooooops! That should…
Ooooooooooops! That should have read - It is recommended that they are bored out to 9/32". Sorry.
Ian.
