          Hello,can anybody tell me where I can buy the plastic/rubber beading for the loose chromedpetrol tank sidepanels for a 1957 ES2? Thank you!
Regards from Svein.
Hi Svein, Norvil sells it,…
OOPS, I forgot to mention,…
OOPS, I forgot to mention, be sure and buy enough extra to go around the edge of the numberplate bracket where it meets the rear fender!!!!!
When installing the beading, push it in from the outside in, do not push it length wise. If you do, it will stretch it out & after you cut it to length, it will shrink back to its normal size and you will end up with a gap at the seam.
Skip
Hello Skip, Thank you very…
Hello Skip,
Thank you very much!! I will order the right type from AMC.
About the dynamo end cover I am sure it is painted black.
Best regards from Svein.
Hi Svein,
Norvil sells it, but it's not the correct original profile, but will work. You can buy the exactly correct stuff from AMC Classic Spares (black):
http://www.amcclassicspares.com/Petrol%20and%20Oil%20Tanks.pdf
023360/1/2 Beading for chrome tank panels: red, blue, black
I have bought some ffom them & it is perfect!!!
All the best,
Skip Brolund
