Sprocket removal
Just been to Kempton and bought 'Norton Motorcycles - a practical guide covering all models from 1932' by E.M. Franks.
Twice he says in reference to removing sprockets (magnetor and engine) "if a suitable sprocket extractor is not available, it is probable that a sharp blow on the sprocket teeth with a brass punch will release the sprockets from their tapers".
I like the optimism in the words 'it is posible'. But is it really possible? And which direction does he mean it should be struck?
Trying to remove the engine sprocket on my Dommy i used everypuller i could find and borrow including hammers and a torch. Eventually i borrowed the correct Norton puller from Les Rogers , The sprocket came off with a big bang and flew. A hammer and punch? ,no way.
The sharp blow is significant. The first time I tried to remove the engine sprocket from my 99 (I wasbut a callow youth at the time) the proper extractor wouldn't budge it. So I borrowed a hydraulic sprocket puller and wound it on. Nothing. I then put a length of tube on the puller T handle and would it up even tighter. Nothing. I peered closely at it to see what was amiss. Couldn't see anything so I started to stand up at which point there was an almighty bang as the sprocket and puller shot through a new gallon can of oil and embedded themselves in the brick wall of the garage. 2 seconds earlier and it would have been through my head, then the can of oil, then into the wall.
What I should have done of course is use the normal puller, wind it up reasonably tight and then tap the end of the puller (or indeed the sprocket using a drift) to shock the sprocket off without danger to cans of oil, walls or even the idiot's head. A bit of a lesson there.
I suppose it could be possible, BUT, I personally don't like hitting anything with a hammer, particularly the magneto sprocket. Every one seams to have a different interpretation of 'HIT'. I have seen too many hammer marks to think otherwise.
Correct pullers is the only way to go on our old machinery.
Indeed. You have to apply a force along the taper - using a puller - and then you can shock the taper to get it to release using an appropriate sharp tap. I watched a foreman fitter remove a taper-fitting track rod end by battering it with a hammer until it released - the taper by this time was b******d. Not the recommended method.
The proper dommy puller is a serious bit of kit. looks too small to do much but applies the force in a direct line and has a fine thread. I would not sell mine .
