WD 16H magneto cam
My 1944 16H is still running rough.
I stripped the points out and noticed I have a face cam in the (MO1L) magneto marked with an L. Someone has suggested the Norton with it's anticlockwise points rotation, viewed from the points end, sould have a cam marked with an R.
Any knowledgeable folk out there know if this is so? And what the L and R indicate? I am hoping that it may be the cause of the poor running :(
I hope someone will know about the L and R - if not I'll take the cover off mine and look. But I'd rather not as the cover is a b***** to remove as you probably know - it's a case of turning the engine round and round until it's 'just so' - and try not to jam the thing and do some damage. But the relatively gentle 'up' ramp with the much steeper 'down' ramp afterwards should be visible.
What timing are you using? Mine runs well now it's 1/2 inch BTDC on full advance. I've seen both 3/16" and 7/16" in different books.
The other issue I had was the top arm of the contact breaker not being square on top of the lower contact but skewed sideways a bit - as a result of the above-mentioned problem replacing the cover.
I had the timing set advanced more than 7/16th and less advanced that 3/16th but the best operation seems to be around 5/16th BTDC.
The symptoms are a general lack of power in all gears with the engine not wanting to push beyond 45mph in top gear and even the slightest incline causing the revs to drop off requiring a change down on the gearbox.
All seems well with the fuel mixture and jetting, the plug looks perfect, light brown deposits and no glazing or soot. Also the bike runs best in 3rd gear, when the revs pick up and making the engine a little thirstier, and various positions on the air lever have little effect, so fuel wouldn't seem to be the problem.
I don't really want to start mucking around with valve timing, it "feels" so much like retarded ignition, but advancing doesn't cure it!!
I have found a dealer who has an "R" cam which he is posting to me tomorrow, I am hoping it will solve the issue, but was interested to know the reasoning for L and R cams. I was assuming that with a single and one spark per rotation of the cam it wouldn't be that critical, unless the dwell angle is seriously affected? I will post the result once I have the cam fitted, fingers crossed.
I'm curious now - I'll have a look this evening. Is it marked on the visible face or on the back? (I'm not stripping it down.)
For lack of power, my E.M.Franks's 'Norton Motorcycles' lists : "no tappet clearance; valve held off seat by loose carbon or my valve lifter; tight front chain or broken piston rings."
The tight front chain is maybe not the first thing that would come to my mind.
Hey Paul,
I'm not 100% sure,but I was told recently the Norton changed the rotation of the Ignition to clockwise from about 1936-37 for about 10 years,this was info regarding the OHV singles of this period,I do not know if it's the same for the side valve??
Regards Darren
Cam arrived today! I have fitted it and the bike starts much more easily and the advance lever actually seems to have an effect on the running of the engine now, so signs are promising.
Will have to wait for tomorrow for an actual test ride though, roads down here are like a river right now.
Photo attached of the R and L cams side by side for comparison.
cams-jpg
That's a good result Paul. Just to confirm that my WD16H (clockwise mag) has an 'R' cam fitted so it looks as if you've arrived at the correct solution.
Thanks Richard, just been on first test run with the newly adjusted magneto and the improvement is clear. Top speed now around 60mph and the pick up has been transformed. In fact it is a little bit hairy on those girder forks on our wonderfully maintained and pothole free roads!
The bike is now idling too fast so I think some tinkering with the carb will follow, :)
16h-jpg
