ES2 tool box
Been tinkering with my ES2 this evening, have straightened out the front mudguard and got the exhaust pipe fitting quite nicely. I noticed that the tool box is only held on by two bolts at the top going through lugs on the frame. This leaves the bottom free and it swings about a bit. Should there be a P clip or something down here? Itâs a â51 plunger frame and thereâs a big gap between the bottom of the box and the lower frame tube and I canât see any mention of it in the parts book, but it does seem a bit flimsy without anything there. Is there anything else securing the toolbox in place?
On my '51 easy2 there is a short plate of which one end isbolted to the backbottom R/H corner of the tool boxand the other end is bolted to the side of the rear guard. I don't know how original this is, but it steadies the box and is almost out of sight, tucked in behind. See if you have a small hole intool box where I describe.
hi andy paul is right a bolt through back of tool box on to rear mudguard
looking at your photos i think your es2 is a 1950 model
regards roger
hi andy if you look at the norton models page on this site you will see my es2 reg no ppc95 you will see the petrol tank is a bit bigger with different knee grips the oil tank is slightly different as are the mountings and i think you should have a t shape battery
regards roger
hi andy also for 1951 they had an alloy front brake plate i think they started fitting these during 1950
regards roger
