19S mudguard question
Hi
Were the mudguards different on 1956 and 1957 models of the 19S.
Ive a 1957 model (with, strangely a laydown gearbox) `M` prefix on the frame and engine. It has a ribbed front mudguard but a plain rear. Should they both match.?
I also have a 19S 1956 `L` prefix on engine and frame with no mudguards at all (and an AMC gearbox, I would have thought the AMC box would be on the later model).
I ask as I have various mudguards, one ribbed rear, one hinged, one plain no hinge and other odds and sods and Im not sure what goes with what.
any help gratefully received.
cheers
John
Hi John,
The ribbed mudguard is possibly AJS/Matchless but without seeing it I can't be sure. Hinged mudguards are 1953-55 in general but some very early 56 models had them. The bad news is that the 56 guard is a year specific part and has a detachable rear section. 57 models also had this but they weren't quite the same, the profile was noticably different.
Jim
Hi John,
I have a 56 19S which is very original & unmolested, the rear guard (& number plate mount) is same shape/profile as that on my 58 Dommy 99, infact the removable rear sections are interchageable between the two. I'm also fairly certain that Kev Feltoes model 77, which I believe is 57, has exactly the same arrangement, being essentially an ES2/19S frame with a 99 engine. Hopefully there should be a couple of pic's attached.
Regards, Tim
Ignore the 3rd url, I added it as an attachment, not an image & apparently I don't have sufficient privilages to delete itindecision
Chris ?smiley
19-rear-guard-003-jpg
www.nortonownersclub.
Hi Tim,
Interesting that your 19s has a 57 style mudguard fitted but then again 55 and 56 were years of messing about in terms of tinware so it is absolutely possible that a mid year produced bike could have slightly different tinware to one produced at the start.
They did this in 53 to the rear mudguard so very early models may have a short hinged mudguard while later have the full length type.
Other tinware was also changed frequently like the petrol tanks which changed four times in four years. 54 had bolt on knee grips, butterfly type cap and a transfer for 'Norton'. 55 had a conventional removablecap round badges and glue on knee grips. 56 had nearly the same setup but they had gone back to bolting the knee grips on. 57 had the chrome panels on the tank sides.
Jim
My 1957 19S has a rear mudguard identical to the one you show in your pic (many thanks for that). I have found a matching plain mudguard to suit.
The 1956 19S definately has a ribbed rear though as the correct registration plate is attached to the mudguard.
Many thanks for your help
Hi John,
Don't forget that AMC whoalso ownedAJS/Matchless bought Norton therefore they started to use AMC parts on them and the rear number plate shown in the pics is an AMC product that was also used on machines with ribbed mudguards. 1956 model Nortons DID NOT have a ribbed rear mudguard.
I know someone who acquired not one but three NOS detachable rear sections for the 1956 mudguard and they weren't ribbed!
Jim
Hi Gents,
Jim, some interesting fact there, I'm still trying to build up a better knowledge of the 19. Mine was registered 15/02/56, so I presume built late 55 or very early 56. Chassis/eng number is L965*** but I don't have any references to check against for a more accurate idea. It has the lay-down type gearbox, Crome tank with painted panels, round badges, conventional removeable cap & bolt on knee grips, the large matching tool/battery box & oil tank, the rear guard as shown & a front guard again the same as the wideline 99.
Regards, Tim
Hi Tim,
Certainly for 1955 the ES2 and 19S shared tinware borrowed from the Model 7 twin with the exception of the petrol tank. I see no reason that the same thing wasn't done for the Model 50 when it came back for the 56 season. In fact doing anything other than this would have been exceptionally stupid and costly.
Jim
Just to throw`t`cat amongst the pigeons.
I have a 19S 1956 frame and matching engine, no. L9 69***, date of original registration 30 May 1956. It has a ribbed rear guard which certainly looks original as it has the original registration plate fitted, it also has an AMC gearbox (of course these could have been changed at any time in the past..accidents and breakdowns etc). The 1956 frame is also different to the 1957 frame and looks as if it has been made specifically for sidecar use, the area around the swinging arm uses different castings and all tubes are straight and brazed in to the castings.
To further add to (my) confusion, the 1957 19S has a ribbed front mudguard with the original number plate fitted, it certainly doesnt look modified in any way since 1957 ( engine and frame no. M97***) and a laydown box ???? which looks original (can you date gearboxes from their numbers).
headache now, need a beer
update, got the front end off the 57 19S... the front mudguard is aluminium..hmmm.. looks original but cant be..can it?
