I am trying to find out who supplies the four rubber mounts for the handlebar clamps for a featherbed Inter. I believe the early featherbed Dominators up to 56 had the same setup. I have the clamps and four pressed washers but the rubbers are perished.
Mark
jeffalanhunter@aol.com He…
Not perfect, but, Commando…
Not perfect, but, Commando fuel tank washers can be modified to fit. RGM have them in stock. John.
Thanks Guys, that gives me…
Thanks Guys, that gives me two options. I will try Jeff & Alan first and the tank washers will be a good backup.
Mark
Previously John Shorter wr…
YES John RGM Motors Have Them In Stock nice there are too. don't for get the cupped washers ! top and bottom , Yours Anna J
The Commando tank washers…
The Commando tank washers are the right thickness, but the holes need enlarging, to take the sleeved nuts, and the outside diameter reducing, to sit in the cup washers. Not a big deal, for a man with a Black&Decker drill!
Can I ask for clarificatio…
Can I ask for clarification please what we are saying here.
What exactly does Jeff Hunter have?
Rubbers or
Dished washers,
or both?
Appreciate I can ask and have but so the discussion is clearer.
Ian
Previously ian_jayne wrote…
Rubbers or
Dished washers,
or both?
Ian
i asked Jeff about the rubber washers, I have given him the sizes for these and am awaiting an answer. I have the dished washers so these are not an issue.
Mark
jeffalanhunter@aol.comHe should have them.Also at Kempton autojumble in the undercover section close to the entrance...David
