Alfin barrel question
I believe I have an Alfin Barrel for an ES2. It has 9 fins which I believe indicates it is an ES2 design barrel. I have some questions though. As I understand from the NOC website the Alfin casting process molecularly bonds the aluminum alloy to the steel sleeve. The barrel I have has a bore diameter of 83.6mm. Also, the amateur machinist has exposed the aluminum from his/her shoddy workmanship. I have attached pictures of the barrel.- Because of the Alfiin process, can this barrel be resleeved with reasonable labor and costs?- If so, what would be a reasonable process to remove the sleeve?- Could this be a Big 4 barrel or just a cobble job?Any and all feedback would be possible. This is my first post and the picture attach process was a little confusing. Thanks.Josh FribleyColumbus, OH USAAttachments
technical
Hello Josh, I would get in touch with Mike Pemberton, the singles expert of the club. he's the man. His contact details are under the 'Technical' heading on the left side of the page.
Adam
Adam
Hello Adam,
Thanks for the information. I have contacted Mike Pemberton and the barrel is indeed an Alfin design.
