Sorry guys more help please - the other leak, (besides the oil bath!!) is from where the kickstart enters the gearbox. Are there seals and 'O' rings as it is not obvious from the various manuals. Thanks
There is supposed to be an…
I forgot - what year is th…
Does that mean it will wor…
Does that mean it will work on my '56? Or doing have to sell the bike and buy an earlier one?
Getting confused about sel…
Thanks David any ideas on…
Thanks David any ideas on sizes?
Sorry - my notes don't sa…
Stuart - I just measured t…
Hi,here is a cure if you h…
Hi,here is a cure if you have the laydown box: You need one 28mmx2mm O ring,one 28mmx2,5mm and two 20mmx1mm.Take out the outer cover,kickstart shaft and put one of the 28mm rings against the shoulder of the shaft.Check the end float so use the best of them.Fit the two 20mm ringsat the two machined rails at the axle.Grease it and put together and I think it is leakfree. Good luck!
Got the seal and took off…
Got the seal and took off the outer cover - expected to see where the seal goes - sadly not! How far into the gearbox do I need to go? Have ordered the club DVD gearbox repair!!
Ive made a cork seal from…
Ive made a cork seal from 1.5mm erm....cork, as original. I havent run it yet so dont know if it leaks. If you are interested drop me an email
if you send me an SAE I will make you one
cheers
John
The seal is described in t…
The seal is described in the parts manual as a compressed cork washer! Are they available?
Apart from the cork washer…
Apart from the cork washer mentioned, if you deepen one of the twogrooves on the kick starter shaftto 1.002" Dia., a number #022 'O ' ring can beslipped onto stop any oil seeping out from between the shaft and bush!
Thanks guys - but can't w…
Thanks guys - but can't work out how to get the kickstart apart. Read all the books but none of them are any real help! Any ideas pleas?
