I am almost ready to re-wire my 1951 ES2 but I need a voltage regulator for it. I am going to fit an AO services electronic one but I want to put it inside the origonal box. However, I dont havean origonal box. I'll have a trawl through boxs at Kempton Park on saturday but I was just wondering which regulator was used? Im guessing it would be a MCR1 or 2?
MCR2 was the regulator use…
Thanks Paul. I'll have a…
Thanks Paul. I'll have a look at the auto jumble on Saturday.
hi andy 1951 nortons have…
hi andy 1951 nortons have the control box in the tool box so you can put your modern one in there and no one would be any the wiser pre 1951 they sat under the seat regards roger
Hi Roger My ES2 is actuall…
Hi Roger
My ES2 is actually a 1950 model year so it would probably be under the seat. I'll have a look round at Kempton tomorrow and see what I come up with. If I come home empty handed it may well go in the tool box,
Andy
Here is my 1951 ES2 with t…
Here is my 1951 ES2 with the electronic regulator fitted in the toolbox
Hi Paul Is that also a mod…
Hi Paul
Is that also a modern oil filter in there?
Andy
G'day Andy, Yes, that is…
G'day Andy,
Yes, that is a small spin on oil filter (the same one I use on wifes Mazda)mounted on an aftermarket Commando type base bought from the NOC shop. Fitted in the return line and utilising some of the original mount holes leftfrom when I removedthe MCR2 regulator. I have fitted the same set up in 3 other bikes in or behind tool boxes with no problem.
MCR2 was the regulator used for the 60 watt generator used on the 1951 ES2. Easily identified by the circular, domedbulge in the middle of one side, to clear the resistor within.
