I have just replaced the leaky head gasket on my 1954 Big 4. Looking in my manual all I can find is (even and snug) no torque settings or tightening order. Am I looking for a problem that is not there, or is there information that I did not find ?Thank you for any help
Minnesota Dave
Mr. Ambler Thank you for y…
Mr. Ambler
Thank you for your information, it is much help. I did not see any torque setting information. Is there a setting number or just snug?
What manual do you have?? I have a copy of the Norton maintance/instruction manual for models 16H ,BIG4 ,18 & ES2 and that page you sent is not in there.
My Big 4 seems to be at the end of the line and some what unusual. It is a Big 4 but with a swinging arm suspension. The frame number has a 8 on top of the numbers 56385 and the motor is 56385 space 82/113 and under the first numbers is the number 8. It also has a "A" painted on the rear mud guard. I have been told this bike was sold to a dealer in Austria. I have not sent this info in to find the history yet. I have also heard the swinging arm was something that could be ordered but not listed as a option.
Can anyone verify this combination?? It is real hard to find information other than this forum due to the fact I live in Minnesota US
Again thanks to all for putting up with my questions. It is a learning session for me and I hate to ask questions that many of have known answers for years and consider common knowledge.
Minnesota Dave
Previously david_rademache…
Previously david_rademacher wrote:
Mr. Ambler
Minnesota Dave
Hi Dave,
you obviously have one of the end of the line model with the aluminum heah, as to torque required I have no idea, I am sue some member has the info to hand.
The info I posted was from the WD16H Norton Maintenance Manual which you can view on www.WDNorton.nl web site.
Best regards
Derek Ambler
I'd be very surprised if…
" When the engine was firs…
"When the engine was first designed, the torque wrench hadn't been invented"
...When the engine was first designed, it didn't even have a detachable cylinder head !
I'd say that tightening in a cross-pattern with just a hand-spanner leverage is important, with a retighten after it's been hot and cooled....maybe more if using a composition gasket.
Like I said, this is a lea…
Like I said, this is a learning curve for me. After working on my 1929 Model "A" and my 1947 Indian motorcycle I'm use to and spoiledby more information than is really needed. I was just worried about the torque settings because I broke a head stud on my VelocetteLE by putting very little pressure on it( I guess it was more pressure than needed).
Again thanks to all who replied and have helped me in the past.
Minnesota Dave
Hi Dave
I have attached the relevant info from the 16H Maintenance manual,
which hopefully explains the very technical requirements!
Derel Ambler
Attachments 16h-big-4-head-tightening-rtf
