Hi
I posted a request last month to see if anyone could upload photos with a scale of a early 50s ES2 chrome tank so that my painter can do an accurate job as possible. I havent received any replies and the tank is gathering dust. I would really appreciate your help on this. Many thanks
Went through the agonies o…
hi william just seen this…
hi william
just seen this message many years ago i had some plans printed of the tank linning i took them from a good original tank if you e mail me your address i will send you a copy if you look at the Models section you will see my 1951 es2 reg no ppc95 regards roger
Hi Roger that would be gre…
Hi Roger that would be great my email is wkpryde@hotmail.com
hi william i meant your po…
hi william
i meant your postal address not email my tel no is 07917334214
Hi Will I have just joined…
Hi Will
I have just joined the group. I have a 1951 ES2 and I basically copied a design I found on the net - that was about 12 years ago. I believe it conforms quite well to what was done in the factory. From my readings, I believe that because they were hand painted, no two are identical. I cannot tell you the exact colours as I simply chose a nice light silver / metalic grey. I am happy to email you some photos of my tank but will have to wait for daylight and after work. my email is rossluff@wirefree.net.au
Ross
Previously william_pryde wrote:
Hi
Went through the agonies of indecision last year. Just now I Googled '1953 Norton' on 'images' and lots come up. But unless someone knows different you aren't likely to get a scale. There are some general trends - the Inters seemed to have a tear-drop shaped side painted panel and the SV and OHV singles had a panel with the rear edge shape fitted about 1/2 inch from the knee grip. But they all seem to be a bit different. Sometimes the knee grip wanders a bit over the panel - so it looks like the factory painters did them quickly by hand. So newly painted ones are maybe more carefully set out than the originals.Bacon's 'Norton Singles' says 1/2" black line until 1952 when the lines on road models went to 1/4". The thin red line would have been whatever the lining brush produced that day - approx 1/8", maybe less.
