Laydown gearbox exchange
I have posted an advert in the classified section under exchanges but would like to draw attention to it here as it's relevant to pre Featherbed single owners. I have a Laydown gearbox, complete and in working order prefixed GT 101 which I'd like to exchange for similar but prefixed GB8 which would fit my Featherbed 88 project.
Thank you in anticipation.
phpwkrddbpm-jpg
I have a GB8 inner case which I believe is the only difference from the standard lay down box. Experts on the forum should be able to confirm.
Thank you Stuart, I may well be very interested. I will have to check the mainshaft length I have as I believe it may be shorter on the boxes intended for singles. I would also be interested to find out if the gear ratios used in the GT 101 are different to the ones used in the GB8 units?
I'll pm you with regard to your case Stuart if that's ok?
