Hello,
Can somebody tell me what the correct pivot center distance is for a 1938 model 18.
7/8" and 1-1/16" pivot centers are avaliable but which one is the correct one?
I assume hÃ?ndlebar diameter for that period is 1"
Thanks for your help.
Bert van Hemert
I believe that you should…
I would try a few old leve…
I would try a few old levers and settle on the smallest c/c which allows clean gearchanging.
My 1937 16H has 1 + 1/8 in…
..and bar diameter is 7/8…
My 38 ES2 has an original…
My 38 ES2 has an original handlebar bracket but is an inch.
I agree with the piggy back levers and large lever throw. I managed to convert the lever bracket for the clutch side from the 7/8 throw by brazing a pin in the pivot hole and redrilling at the correct centres. I found new steel blades (too long and pattern) at Kempton. After modification and rechroming they look and work perfectly.
I'll have to check if the…
Hi all inch and an eighth…
Hi all inch and an eighth is the correct pivot centre as dave says long front brake lever and short clutch lever 1935 handle bars are one inch dia as are most of the wd ones 1937-38-39 all had seven eighths dia bars not sure about 1936
During a lengthy restorati…
During a lengthy restoration of a 1938 CS1, I accumulated a mass of original Norton & associated literature. 'The Motorcycle' September 3rd 1936, has a detailed article on all the mods and specifications for 1937 Norton models.
'With the exception of International machines, all models have a new riding position. saddles have been lowered by 1-1/2", Handlebars have been bought back towards the saddle by 1-3/4"
It goes on - ' An additional feature is the employment of 7/8" handlebars with small diameter grips' So it seems that 7/8" bars were introduced for 1937 models.
'37 model production would have started in late 1936.
No mention of any details on WD models.
1 1/8" is correct for lever pivot centres.
Thanks, Roger & Roger…
Thanks, Roger & Roger for the extra detail...it makes a lot of sense. In most literature, the WD models are referred to as being to 1937 specification but the frames have the vertical saddle spring lugs so are in fact of the 1936 type.
I suspect that the relevant change which brought about the '1937' term was that from the 3rd brush to CVC dynamo.
It also gives a clue as to why 1" combination levers are so difficult to find. They were a WD only fixture from 1937 to 1939 at which point they were supplanted by separate parts.
I believe that you should have 'combination' levers on a 1938 machine, made by Doherty but not branded.
My 1939 WD16H had the broken remains of an original clamp and lever when it came to light after being damaged in 1940.
The centre to centre distance was 1 1/8" and this does turn up from time to time on older levers but I don't believe that any are currently made.
Attachments img_0836-2-jpg
