OHC mag chain lube
How does the mag chain on the inter get its lube?
When I stripped the engine it was packed with grease, it cannot get any oil from the engine and I cannot find anything in the manuals.
Mark
I think you answered your own question Mark, a bit of grease on the chain will do it. you don't need to pack it full though.
Grease is the usual method though oil is supposed to work along the scroll on the bush for the drive shaft, as I remember....
