Big 4 Fork sliders
Hi I've just started working on the forks of my 1950 Big 4 restoration project and hit a possible big problem. The fork slider are excessively worn around the spindle holes without I think enough metal remaining to ream and sleeve. I've been looking around for replacements without any luck as I can find no usable replacements where the chrome sleeve fits over the top and is held in place by 2 screws. I suppose my question is really are the slightly later versions of the slider compatible with the rest of the forks or should I look to replace the whole lot with a later set of forks.
I'd be very grateful for any help or suggestions regarding this.
Chris
NM19310SLIDER - FORK - LEFT HAND - 7,19S,50,77,ES2 & DOMMIE PRE1956
NM19309SLIDER - FORK - RIGHT HAND - 7,19S, 50, 77, ES2&DOMMIE PRE56
These should be compatible with your Big 4 but at £189 each are not exactly cheap. Still, nice to see that someone is prepared to make these for us. I am not sure how long these have been in the Norvil catalogue. For a long time I was under the impression that the only new sliders on the market were for short Roadholders.
Cheers, Ian McD
Thanks for that Ian, I'll keep looking for now but at least I know there is an alternative out there.
Chris
