Fitted valve guides, spring seats are now a little large over the guide, do i need to buy the smaller holed seats, or not?? ,RGM state they are interchangeable, the plot thickens !
Previously marcus_bloomfie…
Previously anna jeannette…
hello you should of check the condition of the valve seats before doing any further work has you need to recut the valve seat after fitting new valve guides I only fit the bronze type of valve guides and you can get valve refaced to if you know what you're doing you can do this job on your own like I do as I have some good tooling like a 10" swing over bed Atlas Metal Lathe and a Smart & brown Milling machine and make all sorts on this tooling do have fun yours anna j
Thats nice, bit i was talking about spring seats, the cup washer type things, now the hole is a tad large, I'll give rgm a bell tomorrow, regards Marcus
