Rim size
Hi All, another question I'm afraid. Can any one tell me what the rim size is for a 1960 es2. I need to order new stainless rims, the old ones are pretty tatty.
The parts book says the font and back have the same part number but doesn't give the WM size, any ideas?
Thanks Rob
Thanks Rob Hello rob if you will take note the size you needs are WM2 Hope this helps yours Anna J Dixon
Thanks Rob
Hi Rob, Be carefull over the tyre sizes,if you have a fully enclosed rear chain case,anything wider than a 350 x19may hit the case mounts,that includes the modern "equivalent" sized alternatives. Norvilles recommended tyres are "decorating" my garage walls, I thought that after restoring Dominators they would be a good source of information ,not so.
Many thanks for the info, I've ordered the spokes and rims, both in stainless.
Thanks a lot Rob
