I have a 1954 ES2 with an engine number beginning with 00. I can't find any reference to such a number in the tables. I can only imagine this is a replacement crankcase following a rebuild at sometime in the distant past. Does anyone have any experience or suggestions of the origin of such a crankcase ? Were replacement cases numbered in any particular way ?
many thanks ... Steve
Hi Niall Many thanks for y…
Hi Niall
Many thanks for your helpful posting. I will have a more detailed look to see if I can locate the extra numbers you mention. She will be ready for an engine rebuild next year and will checkout the pairing numbers then.
Steve
.Previously Niall Topping wrote:
Hi Steve,
could it be a miss-stamp?, does the engine have a shop number?, on the alternator ones at any rate, there is an individual engine number adjacent to the front top mounting lug, these were recorded on the despatch records AFAIK so you could make an enquiry that way to see what bike that engine was fitted to. A replacement crankcase wouldn't have a shop number and as far as I know weren't numbered at all, people used to stamp their initials and birthday on them, that sort of thing.
If you take it apart you could check if the pairing number inside is the same on both sides, at one time you could send half a crankcase back to the factory to have a new half matched to it, whether they numbered them at all after that, I couldn't say.
Good luck finding out,
Cheers,
Niall
Hi Steve,
Cheers,
Niall
