16H horn
Hello all,
The non-original horn on my recently purchased 1946 16H has packed up.
If possible I would like to fit a new horn to match the original.
I would appreciate any advice on what horn I need and where to buy it (and where on the bike it should be fitted...) ?
Many thanks
Hugh
Post WW2 horn whould be a Lucas Atltette 1235.
You can pick these up at any number of autojumbles, or on ebay, but as always, beware those sellers passing off modern replicas as originals, unless you are happy with a replca of course.
If you find a non-working original then Taff the horns (link below) can provide everything that you need to fix it. (this is what I did). It should fit in front of the engine on the top, rear engine stud.
http://taffthehorns.com/
