Good evening
Did a restauration of my engine of the 1939 es2.
Bearings, piston, new valves, springs etc...
Had oil los before the restauration at the timing chain.
I also placed a new andover oil pump. But she is still leaking (too much) of oil through the little tube at the back of the timing cover.
Oil is coming through the hole of the lowest bolt of the timing cover. Added picture.(you can see it when you start without the cover on it.
Can I put a little seal there and lubricate the chain every now and than myself or is it important for the engine pressure ???
I think it can loose pressure at the other site of the engine through the litte breather valve.
Who can give me some advice?
Dirk
Your problem seems like it…
Cam Bushes.
Any oil in the magneto chain area is passing the inlet cam bush. Is the bush badly worn, incorrect or wrongly fitted ?
The exhaust cam bush which is entirely within the timing chest has oil grooves along the whole length of the bush. On the inlet bush which is only intended to pass oil mist onto the chain, the grooves stop about halfway. If the bushes have been swapped then far too much oil will pass. Otherwise, it's likely to be a wear problem.
hello, just found one of my…
hello,
just found one of my blurred photos showing an inlet bush.
barry
Tomorrow i ll look but today…
Tomorrow i ll look but today i let the cover of and started the bike and oil comes through the hole of the bolt beneath and the middle.
There are also made two cuts towards the bolt so oil can pass. Maybe its to much. Tomorrow i ll put two o rings to check it. I ll Sent a foto tomorrow.
Thanks everyone for the advice.
Dirk
Timing chest oil leak.
Hi Dirk,
All the above answers are relevant, but even if the inlet cam bush is very worn the oil should not leak so quickly, unless you have the wrong bush fitted. When you fitted the new oil pump did you check the that fibre washer that fits between the pump and the timing cover was the correct thickness ? This should hold the cover away, when you hold it by hand, by a half millimetre so when you tighten the screws the washer is slightly crushed to form an oil-tight seal. If the fibre washer is missing or not thick enougth the oil will spew out into the chest and not to the big-end bearing. You should also check the oil is returning to the tank O.K. which should be a dribble at tick-over. Another possibility could be the spring in the brass big-end feed quill that runs in the end of the main-shaft which could be missing or broken and allowing oil to leak into the chest.
You should remove the timing cover and check the washer, the pressure release valve, the crank-shaft quill and, if possible, replace the cam-wheel bushes. Also check the engine breather behind the engine sprocket is clear and the ball is free to move so you do not get excessive crankcase pressure.
Your problem seems like it is due to pressure relief valve passing far too much oil. Attached extract from the 1950's manual by F Neill describes how it should work.
