What length should the x2 saddle springs be for my 1937 16h civilian model please?
Levelling up
Yes please Richard. All the…
Yes please Richard. All the springs I can find for my fixings seem to make it ridiculously high at the rear!
thanks
Gary.
I have a pair off the bike…
I have a pair off the bike in a box at present. I'll go out and check later this morning.
1937 16H springs
Picture shows mine. Note they turn in opposite directions so the saddle doesn't tend to twist when loaded.
I think they were painted black, as far as I can tell from some pictures on Vintage Norton Web site. Maybe someone knows.
Thanks David now I just need…
Thanks David now I just need to find a pair- proving rather difficult!
Gary
Spring height.
Gary, I've measured two machines with springs with horizontal lower mounting studs and both are 6 inches from centre of lower eye to top of spring. Don't know if this helps you or not.
I wonder if mine are…
I wonder if mine are squashed by age then? This is one of the best contemporary pictures I've found with mine also. It might be possible to scale (from 19" wheel rim diameter perhaps?). I think they look very similar. Norton proudly advertised the lower seat height (from 1936?)
Seems to be several...
...lug fix on Ebay. (I searched Norton seat Spring). Just be careful, and as advised by David, get a contra wound pair. Some of the picture are not.
J
The only correct answer is 'long enough to bring the rear level with the front mount in use.
Is this a frame with the horizontal spring studs ?
