Despite research I can't find details of the carb retaining nuts for a monobloc 376/017.
Mine have gone walk-about. I believe they should be nylon insert tye but don't have details of the size/thread. Help!
George
If you can get those with a…
carb retaining nuts
Thanks for that Robert but it's the size (5/16"?) and thread (26tpi?) that I'm after,
George
Nyloc
You need Nyloc, or 'Stove nuts' - the ones where the top is slightly 'crushed'. That way they stay tight without overdoing it and you don't end up buckling the carb flange.
As to thread, my thoughts are that they are 5/16" BSF, but happy to be corrected.
Regards, George.
I think they are Cycle…
I think they are Cycle thread, I’ll see if I can have a look later.
Nooky's Nuts...
... have the reduced hex type. You don't need nyloc - just use a single spring washer (not the serrated ones) and tighten till it just flattens. This is enough to stop it coming undone but not enough to distort the flange.
Oh, mine are 5/16" Cycle thread but it's wise to check as the studs may have been changed at some time.
Thank you guys
Thanks guys. That just about covers it. Very grateful.
George
If you can get those with a reduced hexagon as used on the Dommies.
