Does anyone know what thread the 4 3/8 short bolts that secure the rear gearbox plate to the frame spigots is - I assume BSCY? (Single down tube swinging arm frame)
dan
cycle thread on my 99.
gearbox bolts
Hello if you mean the bolts which attach the rear engine plates to the frame down tube, these are normally 7/16" x20 with reduced head to 3/8" whit. If you mean the bolts which attach the the rear plate horizontally above the swinging arm, these are normally 5/16" x 26 again with head reduced to 1/4" whit. Hope that helps.
regards
Andrew
Thanks Andrew, I was coming…
Thanks Andrew, I was coming to the 4 little horizontal ones so you guessed my next questions!
Dan
