1957 Laydown Gearbox (Norton International)
Hi.Could anyone recommend someone to rebuild my gearbox please (north England). It's fully working, but I'm in the middle of a full restoration and would like to get the bearings/bushes replaced.
Alternatively, anyone willing to give me the encouragement & confidence to try myself?!?
.....with the exception of replacing the bushes for the shift mechanism in the side and then possibly honing to fit. So long as you have a heat source to R&R the bearings and understand sorting the mainshaft end float, it ain't rocket science. You might need the  assistance of a service with a press. Give it a go.
Hi Andy,
Your bike’s an International Norton, not t’other way round.
Cheers,
Alan
Hi Ian, Alan, and Michael
Many thanks for your replies. I'll give it a go. I'd already bought the main bearing, bushes and gaskets (Norvil), and can get bearings pressed out with heat at work.
Many thanks
Andy
Hi Andy,
   Just give it a go, they are fairly straight forward. When you strip it, make sure to take photos at each stage of the strip-down and look to see how much wear there is as you remove each component.
   The biggest improvement you can make will be to replace the "pain in the a**e" close ratio gears and fit a standard set from an ES2/16H etc. This will make the bike much more usable, not just in built-up areas, but all-round. As an example with the close set, the difference between 3rd and top gears is about 5mph in top speed so you have, in effect, a 3 speed gearbox. If you poodle along at 3,000 revs in 2nd gear you will be breaking the 30mph speed limit. Best to clean them up and put them in a nice box and impress your friends with your spare set of close gears.
