I am (with luck) finishing the process of getting my 650SS ready for a few weeks(?) pre-winter riding, prior to doing a further re-fit over the winter. Can anybody recommend some ethanol resistant fuel pipe for the machine? It is fitted with a pair of chopped 376 monoblocs, so apart from the line from the tank to the carbs, I require a shortish length for the balance pipe under the inlet tracts, and a further (larger bore) length to supply the fuel from the first (unchopped)carb to the second chopped one.
David Francis.
Fuel pipes
Try AMC Classic Spares as Steve Surby has these Ethanol resistant fuel pipes. I have used them on my own bikes.
