Is it a good idea to add a ball bearing under the clutch pushrod as found with burman gearboxes, I have just stripped down the box to rectify various problems and noticed the pushrod end is wearing into the clutch worm
Ball bearing.
Hi Steven,
Yes, you should fit a ball bearing inside the mainshaft. You need to put this between the clutch mushroom and the long pushrod, so shorten the rod to suit. This won't completely stop the wear, but it is the best method of minimising it.
